SW_
Mar 22, 2019Prodigy
New Orbi RBR50/RBS50 Firmware Version 2.3.1.44
Netgear is pushing out yet another a new Orbi firmware update.
Hopefully it's better than the last version v32.
Please share your experience.
Firmware Update
BobDelp
Mar 22, 2019Guide
| Satellite | RBS50Y | OutDoor | V2.3.0.28 | Update failed |
BrendonSF
Mar 22, 2019Guide
I was auto-upgraded overnight. So far everything is running smoothly.
- FURRYe38Mar 22, 2019Guru - Experienced User
Do you see any "config sync" notices with your system after the update?
Was the update applied and you continued to use the system or did you reset and setup from scratch. Just curious here.
