SW_
Mar 22, 2019Prodigy
New Orbi RBR50/RBS50 Firmware Version 2.3.1.44
Netgear is pushing out yet another a new Orbi firmware update.
Hopefully it's better than the last version v32.
Please share your experience.
Firmware Update
Mar 22, 2019Guru - Experienced User
If you notice odd or bad behavior after the update, do a factory reset and setup from scratch and check again.
thombe wrote:
after downgrading back to 2.2.1.210 after trying manual updates to 2.3.0.32 and finding some dropping and a much weaker WiFi, even after factory resets, I though I would update again to 32 to see if I got the 44 push, which I did
updated via web browser and using the update all button.
update seems to have gone fine in itself, obviously way too early to see if stable or not.
one immediate thing I notice however, via the web browser in the connected devices I see both my orbi router and orbi satellite are shown as windows pc's
thombe
Mar 22, 2019Apprentice
Will do, thank you, its just i did the re-upgrade and upgrade remotely from work, so couldn't actually do a reset yet.
besides, i want to see if there actually is anything else odd before i do that. in particular i want to see if the wifi range is as good as .210 or as bad as .32
Will reset if need be and check.
shall let you all know my findings if anythign worth reporting.
- DEJWMar 22, 2019Aspirant
I got the 2.3.1.44 update pushed to my router, but the satellites are still on the .32 version and showing the config sync status. Is there a link where I can find the firmware update for the RBS50 to the 2.3.1.44 version?
Or will it update automatically if I factory resent?
Thanks
- wildsubnetMar 22, 2019Apprentice
Was auto-updated during the night...despite having disabled that from the CLI. The .32 must have re-enabled it (I checked via CLI, and sure enough...it was enabled) I was only .32 for a day so not really ready to compare. I did have to power cycle the routers after each update to get the backhaul to stabilize on 5G.
- Chuck_MMar 22, 2019Mentor
The IOT "Fix" is very compelling/curious to me... I wonder if there are any other "new" configuration items.
I am at work now, but will check to see if my RBR50 and 3 x RBS50s that were at .32 got upgraded.
Will also check the GUI for both the router and satellite to see if there are any new options.
- SW_Mar 22, 2019Prodigy
If your Satelliete is showing "Waiting for connection" with an old firmware version, login into your Satellite to confirm that it's still stuck with the old version. Once that's confirm, go back to the Router Firmware Update page and click "Manual Update" tab and then click "Online Update" tab. Flipping between these two tabs/pages will force all your Router/Satellites to refresh/recheck.
"Waiting for connection" happens because the Router/Satelliete back haul is stuck in 'Config Resync/Good' cycles, likely as a result of weaker WiFi signal in these newer firmwares since v210. v210 doesn't suffer from this problem.
I have to click these tabs a few cycles, (yeah, it's crazy), in order to catch it in a small window where the Satellites are able to established a "Good" back haul connection to the Router so that they could do their checks and pull the new firmware version.
That's how I got my Satellites to update properly. YMMV.
- thombeMar 26, 2019Apprentice
So after some instability with the .44 from manual update, but no factory reset, I decided to do the full reset and setup from scratch. I have my setup in AP mode.
Initial thoughts, the range is not as good as .210 so already i'm not overly excited.
shall report, but i have to say so far .210 has been the best firmware for me at least.
- FURRYe38Mar 26, 2019Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Thanks for letting us know your experineces...
