SW_
Mar 22, 2019Prodigy
New Orbi RBR50/RBS50 Firmware Version 2.3.1.44
Netgear is pushing out yet another a new Orbi firmware update.
Hopefully it's better than the last version v32.
Please share your experience.
Firmware Update
ReallyAnnoyedAF
Mar 22, 2019Star
Funny thing - I was right in the middle of rolling back to v.2.1.4.16 (hacked the router to stop auto-updates, hacked the satellite to stop auto-updates, ready to load....) when this new version (2.3.1.44) pops up on my router UI. Well, I've wasted the past two weeks with the last round of un-announced manual-double-update-patchware which cut my wifi download throughput in half, **bleep** it, let's see if it works.
Welp, nope - despite solid signal coverage throughout my 3000 sq ft house with a single router and satellite, my wifi download throughput is still only half what it should be (uploads are fine, and everythings runs wire-speed from my ISP to a machine hardwared on my orbi router lan port). But over the air i get download latency and lags, despite solid signal. Trying pinging your satellites eternally - things look great 1ms or less, then....laaagggs.
But hey, at least i've got adware running on my router now letting me know I can pay extra for security.
Hey Netgear - if I sign up to pay for the optional security does it work as well has the half-working wifi I already paid for two years ago?
kthxbai.
SW_
Mar 22, 2019Prodigy
>> ...cut my wifi download throughput in half...
If you've already tried these, then ignore. I was able to improve/restore my download WiFi download speed (400-500Mbps) by doing these:
1. Disable 20/40 MHz Coexistence
2. Preamble Mode: Short Preamble
3. Separate SSIDs for 2.4GHz and 5GHz
4. Enable Implicit BEAMFORMING - Boosts WiFi speed, reliability, & range for all mobile devices
5. Enable WMM (Wi-Fi multimedia) settings
BTW, Disney Circle and Access Control will affect the CPU performance under high traffic loads, i.e., Speed Test.
Good luck!
