SW_
Mar 22, 2019Prodigy
New Orbi RBR50/RBS50 Firmware Version 2.3.1.44
Netgear is pushing out yet another a new Orbi firmware update.
Hopefully it's better than the last version v32.
Please share your experience.
Firmware Update
coretech51
Mar 23, 2019Tutor
I just did my 3rd or 4th reboot of my Orbi router since yesterday due to losing my connection to the internet (ISP). I thought this was happening as a result of updating my firmware to .32. I then discovered that my router and satellites had been updated to .44. Have anyone been having issues with losing their internet connection (ISP)? I use Fios and my router is connected directly to the gateway.
- orbilovMar 23, 2019Apprentice
So just to clarify you have your RBR50 set to AP Mode under advanced?
-Thus your FIOS Quantum router does the routing
-You have disabled Wifi on the Quantum router
Your RBS50 Sat is how far/how many walls/floors etc from RBR and using Wifi backhaul?
- coretech51Mar 24, 2019TutorNo, my RBR50 is NOT set to AP Mode. I only have internet service with Fios and use my RBR50 for routing - no FIOS Quantum router. I have two RBS50 (satellites) in an Ethernet backhaul configuration - one two levels apart in my second floor office and the other in my outside office house. Again, this configuration has been working until the firmware updates. I don’t know what is causing the RBR50 to use its internet connection/service I have, on average, about 58 devices (WiFi and Ethernet) on my network - not running 24/7.
- coretech51Mar 24, 2019TutorCorrection: “I don’t know what is causing the RBR50 to lose its internet connection/service.”
- michaelkenwardMar 24, 2019Guru - Experienced User
What is this "gateway"? (People use that term to describe all sorts of stuff.) Another router of some sort?
Is the Orbi in AP mode?
Clarification: My Orbi RBR50 is connected, via Ethernet CAT6e, directly to the Fios Optical Network Terminal (ONT) and not used in an AP mode.
OK. Not a "gateway" as most people would recognise it, regardless of the label the ISP uses.
- HarryCoApr 12, 2019Initiate
I noticed that after .44 my RBR50 reboots several time a day. At times, my 2 satellites do not reconnect. So, it could be that your symptom of "loosing Internet" comes from the rebooting. Keep a close eye. Nothing has worked for me so far. Good Luck
- FURRYe38Apr 12, 2019Guru - Experienced User
Is the Orbi system operating in Router or AP mode?has a factory reset and setup from scratch been performed since v44 was applied?
Did you update to v44 via the auto update feature or manually download and install the files?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
What WPA security modes are you using?Try enabling Beamforming and MIMO and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).I saw 7+ days of up time with out any problems with the system I have. I'm now running in AP mode.
