SW_
Mar 22, 2019Prodigy
New Orbi RBR50/RBS50 Firmware Version 2.3.1.44
Netgear is pushing out yet another a new Orbi firmware update.
Hopefully it's better than the last version v32.
Please share your experience.
Firmware Update
coretech51
Mar 23, 2019Tutor
I just did my 3rd or 4th reboot of my Orbi router since yesterday due to losing my connection to the internet (ISP). I thought this was happening as a result of updating my firmware to .32. I then discovered that my router and satellites had been updated to .44. Have anyone been having issues with losing their internet connection (ISP)? I use Fios and my router is connected directly to the gateway.
michaelkenward
Mar 24, 2019Guru - Experienced User
What is this "gateway"? (People use that term to describe all sorts of stuff.) Another router of some sort?
Is the Orbi in AP mode?
- coretech51Mar 24, 2019Tutor
Clarification: My Orbi RBR50 is connected, via Ethernet CAT6e, directly to the Fios Optical Network Terminal (ONT) and not used in an AP mode.
- michaelkenwardMar 24, 2019Guru - Experienced User
OK. Not a "gateway" as most people would recognise it, regardless of the label the ISP uses.
- Joboo7777Mar 24, 2019Apprentice
Have you performed a Factory reset?
No, I have not yet performed a factory reset. This will be the next step if I lose service again today.
