SW_
Mar 22, 2019Prodigy
New Orbi RBR50/RBS50 Firmware Version 2.3.1.44
Netgear is pushing out yet another a new Orbi firmware update.
Hopefully it's better than the last version v32.
Please share your experience.
Firmware Update
michaelkenward
Mar 24, 2019Guru - Experienced User
coretech51 wrote:
I use Fios and my router is connected directly to the gateway.
What is this "gateway"? (People use that term to describe all sorts of stuff.) Another router of some sort?
Is the Orbi in AP mode?
coretech51
Mar 24, 2019Tutor
Clarification: My Orbi RBR50 is connected, via Ethernet CAT6e, directly to the Fios Optical Network Terminal (ONT) and not used in an AP mode.
- michaelkenwardMar 24, 2019Guru - Experienced User
OK. Not a "gateway" as most people would recognise it, regardless of the label the ISP uses.
- Joboo7777Mar 24, 2019Apprentice
Have you performed a Factory reset?
- coretech51Mar 24, 2019Tutor
No, I have not yet performed a factory reset. This will be the next step if I lose service again today.
- gr8shoMar 24, 2019VirtuosoYou have great patience. I would have nuked (factory reset) it at the first sign of trouble.
Btw, 58 devices is impressive. Any issues with WiFi calling if you use it? Any streaming issues?
