SW_
Mar 22, 2019Prodigy
New Orbi RBR50/RBS50 Firmware Version 2.3.1.44
Netgear is pushing out yet another a new Orbi firmware update.
Hopefully it's better than the last version v32.
Please share your experience.
Firmware Update
gr8sho
Mar 25, 2019Virtuoso
Hello, I don’t know the answers to your questions, but if you do go ahead with the reset, let us know if it clears up the problem and puts things right.
I’d also say if you’re worried about settings, I’d be sure to have a verifiable backup plan. I’d probably re-enter the settings manually anyway to be safe.
datascope11
Mar 25, 2019Aspirant
I have tried a full reset on both router and satellite, setup again from scratch. Still says "Service Unreachable" on firmware update page. Stuck on .32? Anyone have any suggestions?
- gr8shoMar 25, 2019VirtuosoIIRC, there is a procedure to connect a device like a PC to the Orbi and flash the firmware that way. You should be able to download the file from the NG website, however last time I looked I couldn't find it myself.
- datascope11Mar 25, 2019Aspirant
Yes, I am familiar with the manual firmware update procedure. However on the Netgear firmware page, only .32 is listed and not the new .44. As I understand it, .44 update is an auto update only through the Orbi's firmware update process. Getting really tired of rebooting, manual updates, factory resets... starting to regret Orbi purchase...
- DougB628Mar 28, 2019Apprentice
2.3.1.44 firmware can be downloaded here:
https://kb.netgear.com/000060756/RBR50-RBS50-Firmware-Version-2-3-1-44
- michaelkenwardMar 25, 2019Guru - Experienced User
gr8sho wrote:
....however last time I looked I couldn't find it myself.Because 2.3.1.44 is not there, which is the point of many of the messages in this conversation.
If it is like other firmware, it may show up eventually.
