SW_
Mar 22, 2019Prodigy
New Orbi RBR50/RBS50 Firmware Version 2.3.1.44
Netgear is pushing out yet another a new Orbi firmware update.
Hopefully it's better than the last version v32.
Please share your experience.
Firmware Update
Mar 25, 2019Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
datascope11 wrote:
My Orbi has been like this for a few days now. It continues to say "service unreachable" in the Firmware Update section. I'm on .32. Since upgrading to .32 I've been having experiencing random drops and outages.
Model Name Device Name Current Version Status Router RBR50 RBR50 V2.3.0.32 Service unreachable Satellite RBS50 Orbi Satellite-1 V2.3.0.32 Service unreachable
How can I get it to recognize the new firmware? Do I need to factory reset, and if so - does my backup file contain all things necessary? (Address Reservation, Port Forwards, DDNS settings etc...)?
datascope11
Mar 25, 2019Aspirant
Since fatory reset, connectivity seems to be much better. Haven't experienced any drops all day. I cannot however, seem to get the router/satelitte to find the .44 firmware (Service Unreachable). I suspect it's because I am in Canada, and the current firmware page for .32 says not to update if you are in Canada. Note, it did not say that a week ago when I updated. Not sure they make much differnece to this problem, but here are the specs you requests.
- Modem is Hitron CDA3.
- Orbi connected in Router model
- ~3000 sqft
- Distance between Router and Satellite is approx. 35 ft
- Channels are currently auto, I've tried different channels. No difference to missing firmware.
- I can currently see 3-6 ssids from my home, depending on device.
- FURRYe38Mar 25, 2019Guru - Experienced User
Well since you modem doesnt' have a built in router, we can rule this out.
Possible that NG maybe servicing the auto update servers and not allowing any access. I would not fret over it.
Run the system for a while on v32 and see how it does. No need to rush in to v44 just yet.
- ~3000 sqft
- Chuck_MMar 25, 2019Mentor
Until FURRYe38 's response above, I was going to suggest for diagnostic purposes to do a "Tracert" to any known location to see what the first two hops were (are they private IPs) which may indicate another router involved somewhere (double nat).
- datascope11Mar 25, 2019Aspirant
Thanks guys, definatly no double NAT possibilities here. I'll hold tight for a couple days to see if .44 starts appearing for Canada customers who have updated to .32 (saw a post on page 2 here where someone else had this same thing). If the drops continue though, I'm rolling back to .210.
