SW_
Mar 22, 2019Prodigy
New Orbi RBR50/RBS50 Firmware Version 2.3.1.44
Netgear is pushing out yet another a new Orbi firmware update.
Hopefully it's better than the last version v32.
Please share your experience.
Firmware Update
skippybosco
Mar 22, 2019Guide
Here is the text based:
Changelog:
- [Bug Fix] Fix issues with the Apple HomeKit connectivity
- [Bug Fix] Fixes the wireless crash and reboot issue when the router is under stress
- [Bug Fix] Fixes the WiFi disconnection and IOT issue
- [Bug Fix] Fixes the guest isolation issue for multicast and broadcast traffic breween the main host and guest
- [Bug Fix] Fixes the Ethernet backhaul boot-sequence issue
- [Bug Fix] Updates the OpenVPN certificate from MD5 to SHA-256
- [Bug Fix] Fixes the JP/AU/CA region can't firmware update issue
- [Bug Fix] Fixes Armor activation failed due to device offline issue
orbiRBK50user
Mar 26, 2019Aspirant
Do you have the download link to the latest Orbi RBK50 firmware (v2.3.1.44)?
I manually updated to 2.2.1.212 then 2.3.0.32 then performed a complete paperclip reset on everything. Since the x.32 update, the system has automatically updated to v2.3.1.44. However, I prefer to always download the file and perform a manual update then a reset. The RBK50 support page does not yet list x.44.
On a minor note, since autoupdating to v2.3.1.44, the Orbi iOS app has popped up a notification at least twice during the midnight hours stating "Your device 4Pxxxxxxxxxx75 has been upgraded to version v2.3.1.44"... seems a bit odd it keeps notifiying me every other night making me wonder if it's stuck in a loop on re-updating.
Thus my preference for performing a manual update followed by a complete system reset.
I would appreciate the link if you or anyone has it handy.
TIA
- FURRYe38Mar 26, 2019Guru - Experienced User
v44 is only available via auto update in the routers web page.
Files have not been posted as of yet for manual download.
TIA
