SW_
Mar 22, 2019Prodigy
New Orbi RBR50/RBS50 Firmware Version 2.3.1.44
Netgear is pushing out yet another a new Orbi firmware update.
Hopefully it's better than the last version v32.
Please share your experience.
Firmware Update
MikeTheActuary
Mar 28, 2019Tutor
For whatever it's worth....
I was on .16, having disabled auto-updates due to issues with .210.
Encouraged by some of the comments in this thread, I decided to do a manual update, going first to .212, and then to .44, without obvious issue.
Here's hoping that whatever was causing the periodic disconnects under .210 is fixed!
- FURRYe38Mar 28, 2019Guru - Experienced User
Good to hear. Let us know how it goes.
- MikeTheActuaryMar 29, 2019Tutor
Well, this is not promising.
Several hours after the upgrade, I tried connecting to the built in VPN server. The router immediately locked up and had to be manually rebooted.
A few minutes ago, the router decided to reboot for no obvious reason.
I'll give it a few more hours. If I get a random reboot again, I'll attempt a reset. If that doesn't resolve it, I'll downgrade back to .16 and look into alternatives again.
- FURRYe38Mar 29, 2019Guru - Experienced User
Ok, let us know how the reset and setup from scratch goes.
- FuntasticoMar 29, 2019Aspirant
Was automagically updated from .32 to .44 (Europe). Of course all IPs changed - bummer! - but otherwise seems to be smooth.
Got 22 devices running- what bugs me is that NG sometimes doesn’t know their names - bad database?
And to followup to my prior post... another random reboot lead to a rather vocal set of complaints from the wife....and in the interest of marital harmony, I shifted back down to .16...twice. (One immediate auto-upgrade finally taught me to disconnect the router from the modem when downgrading, so as to avoid the router and satellite auto-upgrading before I disabled that functionality.)
- gr8shoMar 29, 2019VirtuosoWould it be correct to assume downgrade also comes with factory reset?
