SW_
Mar 22, 2019Prodigy
New Orbi RBR50/RBS50 Firmware Version 2.3.1.44
Netgear is pushing out yet another a new Orbi firmware update.
Hopefully it's better than the last version v32.
Please share your experience.
Firmware Update
MikeTheActuary
Mar 29, 2019Tutor
And to followup to my prior post... another random reboot lead to a rather vocal set of complaints from the wife....and in the interest of marital harmony, I shifted back down to .16...twice. (One immediate auto-upgrade finally taught me to disconnect the router from the modem when downgrading, so as to avoid the router and satellite auto-upgrading before I disabled that functionality.)
gr8sho
Mar 30, 2019Virtuoso
Would it be correct to assume downgrade also comes with factory reset?
- MikeTheActuaryMar 30, 2019Tutor
gr8sho wrote:
Would it be correct to assume downgrade also comes with factory reset?Knock wood, my Orbi has functioned as expected without needing a reset after the downgrades.
I'll probably do a reset anyway at some point this weekend...when my wfie isn't trying to stream video or facetime with family....
