SW_
Mar 22, 2019Prodigy
New Orbi RBR50/RBS50 Firmware Version 2.3.1.44
Netgear is pushing out yet another a new Orbi firmware update.
Hopefully it's better than the last version v32.
Please share your experience.
Firmware Update
DougB628
Mar 29, 2019Apprentice
So after I updated to 2.3.0.32, my Orbi updated on its own to 2.3.1.44. Initially, the problems that appeared seemed to be related to what I had seen with DHCP responses not being accepted by clients, and my log filling up with DHCP requests and responses for the same devices. So apparently that issue has not been fixed. Considering the often recommended path of factory resetting when upgrading firmware, I really have to question the logic of automatic firmware upgrades. Its practically begging for problems. Frankly, I think that if a firmware upgrade is not compatible with a prior version's config backup, it should not be applied automatically.
I have since factory-reset, and then used my script-based system of saving my device names, models, types, DHCP reservations, wireless SSID's, UPNP settings, access control settings, and email notification settings to restore most of my config. My script effectively writes a script that will restore my settings based on using "config show" to export the settings (using grep to filter them) and sed to filter those export files to "config set" commands to restore them. I think it's a fairly safe way to preserve the most tedious parts of my configuration across firmware upgrades.
Hopefully things will settle down, and we'll see how well 2.3.1.44 works for me. I've seen that it has not worked for all users, but seems stable for some...
Bullyterrier
Mar 30, 2019Star
I’ve updated my 40 series to .44 now it’s been quietly released.
My satellite that happily showed 5g good connection for almost a year across various firmwares now shows 5g poor (I have reset the world a few times and it’s a solid change for the worse). Downgrade - shows good. Upgrade - shows poor. Looking at reported rssi across a number of fixed position devices they all show reduced signal with 44. Disappointing to say the least.
