SW_
Mar 22, 2019Prodigy
New Orbi RBR50/RBS50 Firmware Version 2.3.1.44
Netgear is pushing out yet another a new Orbi firmware update.
Hopefully it's better than the last version v32.
Please share your experience.
Firmware Update
Chuck_M
Mar 30, 2019Mentor
I wonder if that is because they REALLY are connecting to the RBR or if they are just REPORTING that they are connected?
Wondering out loud what the best method of checking this is. have you compared the web gui with the phone ap on connections to see if they are reporting the same?
SkolViking
Mar 30, 2019Aspirant
Yeah I checked both, I mainly use the web gui. And the main reason I know it is accurate is because they show on 2.4Ghz with low signal which before they we're on 5Ghz with full signal.
- Chuck_MMar 30, 2019Mentor
Stupid question... but I will ask anyway. Have you powered Orbi totally off for 30 seconds and cranked it back up? (Including satellites)
- SkolVikingMar 30, 2019AspirantYup several times. I even power cycle my cameras and they just go back to the main RBR50 everytime. Wonder if I can remove the satellite and re adding it will do anything ?
- FURRYe38Mar 30, 2019Guru - Experienced User
Was the FW updated thru the autoupdate? If so, try a factory reset and setup from scratch on both RBR and RBS.
