SW_
Mar 22, 2019Prodigy
New Orbi RBR50/RBS50 Firmware Version 2.3.1.44
Netgear is pushing out yet another a new Orbi firmware update.
Hopefully it's better than the last version v32.
Please share your experience.
Firmware Update
Chuck_M
Mar 30, 2019Mentor
Stupid question... but I will ask anyway. Have you powered Orbi totally off for 30 seconds and cranked it back up? (Including satellites)
SkolViking
Mar 30, 2019Aspirant
Yup several times. I even power cycle my cameras and they just go back to the main RBR50 everytime. Wonder if I can remove the satellite and re adding it will do anything ?
- FURRYe38Mar 30, 2019Guru - Experienced User
Was the FW updated thru the autoupdate? If so, try a factory reset and setup from scratch on both RBR and RBS.
SkolViking wrote:
Yup several times. I even power cycle my cameras and they just go back to the main RBR50 everytime. Wonder if I can remove the satellite and re adding it will do anything ?- orbilovMar 30, 2019Apprentice
Got Frustrated with Verizon's recent firmware update to their Quantum router bringing up certificate errors for login and decided to take the plunge and release the DHCP lease on the Verizon router and move the Ethernet connection directly to the Orbi. ** You have to put the Orbi in Router mode first or you will kind of get stuck and have to start the process over. Otherwise, it just works.
No issues so far. 2.3.1.44 is the first release I have tried the Router mode versus AP I had been using. Performance/signal strength/speed has actually improved a bit in my limited testing.
- FuntasticoMar 31, 2019Aspirant
The traffic meter seems broken now - at least in the iOS app. Doesn’t show anything since .44.
