SW_
Mar 22, 2019Prodigy
New Orbi RBR50/RBS50 Firmware Version 2.3.1.44
Netgear is pushing out yet another a new Orbi firmware update.
Hopefully it's better than the last version v32.
Please share your experience.
Firmware Update
SkolViking
Mar 30, 2019Aspirant
Yup several times. I even power cycle my cameras and they just go back to the main RBR50 everytime. Wonder if I can remove the satellite and re adding it will do anything ?
Mar 30, 2019Guru - Experienced User
Was the FW updated thru the autoupdate? If so, try a factory reset and setup from scratch on both RBR and RBS.
- orbilovMar 30, 2019Apprentice
Got Frustrated with Verizon's recent firmware update to their Quantum router bringing up certificate errors for login and decided to take the plunge and release the DHCP lease on the Verizon router and move the Ethernet connection directly to the Orbi. ** You have to put the Orbi in Router mode first or you will kind of get stuck and have to start the process over. Otherwise, it just works.
No issues so far. 2.3.1.44 is the first release I have tried the Router mode versus AP I had been using. Performance/signal strength/speed has actually improved a bit in my limited testing.
- FuntasticoMar 31, 2019Aspirant
The traffic meter seems broken now - at least in the iOS app. Doesn’t show anything since .44.
- FURRYe38Mar 31, 2019Guru - Experienced User
Seems to be a known issue.
Revert back to v210 if you need TM working or wait for NG to fix it.
Good to hear. Thanks for letting us know.
Enjoy. :smileywink:
