SW_
Mar 22, 2019Prodigy
New Orbi RBR50/RBS50 Firmware Version 2.3.1.44
Netgear is pushing out yet another a new Orbi firmware update.
Hopefully it's better than the last version v32.
Please share your experience.
Firmware Update
Apr 01, 2019Guru - Experienced User
Has a factory reset been performed and setup from scratch?
Was yoru system updated to v44 via auto update or manual file load?
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
What WPA security modes are you using?
Try enabling Beamforming and MIMO. Under Advanced Tab/Advanced Settings/Wireless Settings
LadySapphy wrote:
Sigh, So 15 months with orbi and it has been a roller coaster of love and hate. This new firmware has put me back into the hate side of things. Yesterday I had to reboot the router 2Xs to get it to work again. Of all the issues I have had, this is the first time I have had it just stop routing.
orbilov
Apr 01, 2019Apprentice
Catching middle of thread but if you are using a router besides Orbi please make sure Orbi is in AP mode not Router mode. This is not auto dectected. Router mode is the default. The double natting can cause huge issues for most, even for devices wired to a Satellite or Orbi router.
