SW_
Mar 22, 2019Prodigy
New Orbi RBR50/RBS50 Firmware Version 2.3.1.44
Netgear is pushing out yet another a new Orbi firmware update.
Hopefully it's better than the last version v32.
Please share your experience.
Firmware Update
Dfran1
Apr 01, 2019Apprentice
my IFTTT app is not working like it used to all the time , now it works sometimes at best!
WiFi is worse , devices connect to the wrong satellite or base, not enough bandwidth errors from my direct tv now app at times due to devices all connecting to satellite and not much to the base ..... certainly not like on 210. A reboot will fix these on the orbi but the orbi will put it all back on the satellite over time.
looks like I need to downgrade to v2.2.1.210 that worked great, I’ll give it a little longer but downgrading seems like the best option if that works properly.
Apr 01, 2019Guru - Experienced User
Try a manual FW file load of v44 and a factory reset and setup from scratch next time you update.
