SW_
Mar 22, 2019Prodigy
New Orbi RBR50/RBS50 Firmware Version 2.3.1.44
Netgear is pushing out yet another a new Orbi firmware update.
Hopefully it's better than the last version v32.
Please share your experience.
Firmware Update
Loungepuppy
Apr 02, 2019Aspirant
The update tab in weblogin showed up today. I assume I set autoupdate to "off" at some point when I was on 2.2.1.212
It's difficult to decide wether to update or not just browning through these posts. Often I find that there is a problem-bias in forums. In this case, I guess that a lot or routers have autoupdated and users have not had problems or enough problems to find this forum and post.
Since a factory reset is an investment in time I will hold off a bit longer and watch this thread...
Apr 02, 2019Guru - Experienced User
A factory reset is worth the time. Helps ensure the system cleared out any lingering mis-configurations or bad code.
