SW_
Mar 22, 2019Prodigy
New Orbi RBR50/RBS50 Firmware Version 2.3.1.44
Netgear is pushing out yet another a new Orbi firmware update.
Hopefully it's better than the last version v32.
Please share your experience.
Firmware Update
BartleyR7
Apr 03, 2019Aspirant
Has anyone else noticed WiFi speeds that degrade over time with this latest firmware? I only have a few data points (just updated ~48 hours ago), but already I've had to power cycle my router and satellite twice to get speeds back up to normal. I normally have around 300Mbps down / 12MBps up, but after the router has been up for ~5 hours, all WiFi speeds dramatically degrade to cap around 30Mbps down. I've tested this on a Mac (macOS 10.14.4) and multiple iOS devices (all running 12.2) and get the same results. But this only affects WiFi. If I plug directly into the router or satellite, I still get normal speeds. When I power cycle the router and satellite, everything returns to normal for a while but seems to degrade.
I did disable implicit beamforming and MU-MIMO (separately to test) to see if that helps. Having implicit beamforming off but MU-MIMO on didn't seem to matter. Now I'm testing with both off.
I'm using the Orbi in AP mode (1 router, 1 satellite) behind an EdgeRouter 4. No Ethernet backhaul.
lukpac
Apr 03, 2019Apprentice
For what it's worth, I haven't had that issue. I just got 322/320 from my iPhone 6s last night, and my system has been up for over a week.
