SW_
Mar 22, 2019Prodigy
New Orbi RBR50/RBS50 Firmware Version 2.3.1.44
Netgear is pushing out yet another a new Orbi firmware update.
Hopefully it's better than the last version v32.
Please share your experience.
Firmware Update
Apr 03, 2019Guru - Experienced User
Thank you for answering the questions.
If you do have other wifi neighbors, i would try reducing the power output of the Orbi, Under Advanced Tab/Advanced Settings/Wireless Settings. See if the problem continues.
A factory reset maybe needed. Seen others post were problems appeared after an update. A reset helps. Yes, I agree, NG really needs to get the update and continue problem resolved. For those of us, we do our own resets and setup from scratch. Seen problems with lingering bad configurations or older code that doesn't work right with a update and continue. Reset clears this out.
