SW_
Mar 22, 2019Prodigy
New Orbi RBR50/RBS50 Firmware Version 2.3.1.44
Netgear is pushing out yet another a new Orbi firmware update.
Hopefully it's better than the last version v32.
Please share your experience.
Firmware Update
SW_
Apr 05, 2019Prodigy
I had similar issue, but I was using two separate SSIDs.
Go to the Orbi router Firmware Update page and check if those Satellites are stuck in "Waiting for connection" instead of "No new firmware version available".
Rustyy
Apr 05, 2019Tutor
Hi SW_
When I first got the Orbi's I split the SSID's. Mine are doing exactly what you mentioned. Waiting for connection.
What is your suggestion to fix this?
Adding the RBS40 to my network not too long ago, I almost took it all back. Now this.
Netgear - give people the option to update firmware! Don't make everyone!
