SW_
Mar 22, 2019Prodigy
New Orbi RBR50/RBS50 Firmware Version 2.3.1.44
Netgear is pushing out yet another a new Orbi firmware update.
Hopefully it's better than the last version v32.
Please share your experience.
Firmware Update
SW_
Apr 05, 2019Prodigy
Mine was definitely slower with v44 than v210, but not half.
This might not matter in your case since your speedtest was good prior to latest firmware update, but give this a shot and see if it makes any difference. If you already did this, then ignore.
- Disable 20/40 MHz Coexistence
pablohoney
Apr 06, 2019Luminary
I tried that to no avail. I also tried disabling and re-enabling advanced settings also to no avail. Something is dragging down the download speed and I don’t know what :(
