SW_
Mar 22, 2019Prodigy
New Orbi RBR50/RBS50 Firmware Version 2.3.1.44
Netgear is pushing out yet another a new Orbi firmware update.
Hopefully it's better than the last version v32.
Please share your experience.
Firmware Update
pablohoney
Apr 06, 2019Luminary
Anyone have a link to the previous firmware version as I want to revert to it?
- michaelkenwardApr 06, 2019Guru - Experienced User
Usual place. Find the support pages for your hardware and take it from there.
Orbi RBR50 | WiFi System | NETGEAR Support
and
- pablohoneyApr 06, 2019LuminaryThanks. Is it safe to revert from 2.3.1.44 back to 2.3.0.32 directly?
- SW_Apr 06, 2019Prodigy
Yes, it's safe to revert back to v32.
To lock it down and prevent auto-update, you can follow this:
mith_it wrote:
>> If you manually downgrade to .210 you can then telnet and disable autoupdates. See https://www.reddit.com/r/orbi/comments/8ke43v/how_to_disable_autoupdate/dz6xz9l/
>> This worked fine for me. As far as I can tell, once you update to .44 if you change those settings it will autoupgrade once (even if you're already on .44) and then not do it again.
