SW_
Mar 22, 2019Prodigy
New Orbi RBR50/RBS50 Firmware Version 2.3.1.44
Netgear is pushing out yet another a new Orbi firmware update.
Hopefully it's better than the last version v32.
Please share your experience.
Firmware Update
pablohoney
Apr 06, 2019Luminary
Anyone have a link to the previous firmware version as I want to revert to it?
michaelkenward
Apr 06, 2019Guru - Experienced User
Usual place. Find the support pages for your hardware and take it from there.
Orbi RBR50 | WiFi System | NETGEAR Support
and
- pablohoneyApr 06, 2019LuminaryThanks. Is it safe to revert from 2.3.1.44 back to 2.3.0.32 directly?
- SW_Apr 06, 2019Prodigy
Yes, it's safe to revert back to v32.
To lock it down and prevent auto-update, you can follow this:
mith_it wrote:
>> If you manually downgrade to .210 you can then telnet and disable autoupdates. See https://www.reddit.com/r/orbi/comments/8ke43v/how_to_disable_autoupdate/dz6xz9l/
>> This worked fine for me. As far as I can tell, once you update to .44 if you change those settings it will autoupgrade once (even if you're already on .44) and then not do it again.
- pablohoneyApr 06, 2019LuminaryI’ll report back if it fixes my download speed. I thought it maybe the wifi but I connected my laptop to one of the ethernet ports on the main Orbi router and the download speed was similar to the wifi. It’s strange as I’ve had no real issues with previous firmware versions.
