SW_
Mar 22, 2019Prodigy
New Orbi RBR50/RBS50 Firmware Version 2.3.1.44
Netgear is pushing out yet another a new Orbi firmware update.
Hopefully it's better than the last version v32.
Please share your experience.
Firmware Update
Joboo7777
Apr 06, 2019Apprentice
I'm running a default config of .44 on RBR50/RBS50 setup. Only settings I changed were enabling MU-MIMO and Implicit Beamforming. I have not see any decrease in speed from my iPhone 8(or any other devices for that matter). I'm wondering if the issues people are seeing are more related to the state of wireless after the reboot required to install firmware vs the actual firmware itself. Being in the IT field, I've seen upgrades and/or patches blamed for issues when the reboot required to apply the patch/upgrade has been the root cause. From what I understand everytime you reboot your wireless there is a potential for the channles used to change which could create variations in performance. Maybe this could be the issue.
Apr 06, 2019Guru - Experienced User
Seen many issues with Orbi. Some has been FW. Mostly other issues are mis-configurations. Yes, Beamforming and MIMO should be enabled along with WMM. Seen it were somehow WMM gets disabled. WMM should always be enabled. MIMO is not as important due to some users ma not have MIMO supporting devices. Beamforming is always good to have on.
Also FW updates seem to go back on auto updates and continuing rather than doing a factory reset and setup from scratch. Seems that lingering old code and configurations seems to not migrate well into newer FW. Factory resets and setup from scratch clears this up in most cases.
- jweiseApr 06, 2019Apprentice
This had been a bad week for me and 2.3.1.44. System has be disconecting once or twice every day.
When it is working it works well at full speed. Believe that 44 is worse than last 2 versions.
- FURRYe38Apr 06, 2019Guru - Experienced User
Has a full factory reset been performed since v44 was applied?
I would do this as well, manually re-load v44 on to the RBR and RBS. Factory reset, setup from scratch.
I changed the default pool size to .100 thru .200.
WMM, Beamforming and MIMO enabled. Disabled Daisy Chain and Fast Roaming. Set 40Mhz only.
Manual channels 11 and 48.
Disable Guest Netword SSID broadcast and IGMP Proxying.
Save, apply and reboot.
Did this 4+ days ago, zero problems. 1 RBS50 is wire connected.
System Uptime 04:20:16:11
- Joboo7777Apr 06, 2019ApprenticeFor anyone interested, just set up a new orbi for a Friend and the auto update is now working from .210 to .44
Will do reset on Monday.
pool size .100 t0 .200?
40 mhz only?
11 and 48?
tks
