SW_
Mar 22, 2019Prodigy
New Orbi RBR50/RBS50 Firmware Version 2.3.1.44
Netgear is pushing out yet another a new Orbi firmware update.
Hopefully it's better than the last version v32.
Please share your experience.
Firmware Update
Apr 06, 2019Guru - Experienced User
Has a full factory reset been performed since v44 was applied?
I would do this as well, manually re-load v44 on to the RBR and RBS. Factory reset, setup from scratch.
I changed the default pool size to .100 thru .200.
WMM, Beamforming and MIMO enabled. Disabled Daisy Chain and Fast Roaming. Set 40Mhz only.
Manual channels 11 and 48.
Disable Guest Netword SSID broadcast and IGMP Proxying.
Save, apply and reboot.
Did this 4+ days ago, zero problems. 1 RBS50 is wire connected.
| System Uptime | 04:20:16:11 |
jweise wrote:
This had been a bad week for me and 2.3.1.44. System has be disconecting once or twice every day.
When it is working it works well at full speed. Believe that 44 is worse than last 2 versions.
jweise
Apr 06, 2019Apprentice
Will do reset on Monday.
pool size .100 t0 .200?
40 mhz only?
11 and 48?
tks
