SW_
Mar 22, 2019Prodigy
New Orbi RBR50/RBS50 Firmware Version 2.3.1.44
Netgear is pushing out yet another a new Orbi firmware update.
Hopefully it's better than the last version v32.
Please share your experience.
Firmware Update
ealthoff
Apr 06, 2019Aspirant
Is anyone having an issue where the satellite isnt showing any connected devices? I saw discussion on an older firmware but I have version 2.3.1.44 and its still not showing any of my household devices connecting. Will this issue get fixed?
- RustyyApr 06, 2019Tutor
Yeah, I just checked my connected divices list. They are all connected to the router other than my PC which is upstairs which is connected via Ethernet. Explains the speed test too as near that my wireless divices get 100+ rest of the house 15-40.
WHY DID THEY BREAK SOMETHING THAT WAS WORKING!?!?!?!?!?!?!??!?!?!!?edit* In fact, checking the "Network Map" on the app. Both of the satellites are purple with only the router green. The "Waiting to connect" curse continues.Looks like factory reset might be the only option which I have tried to avoid, with all the drama I had adding the RSB40 to the system.
- DougB628Apr 09, 2019Apprentice
I have a different problem - my satellites show devices connected to them that are also shown as connected to the other satellite or the router. So it's hard to tell what the device is actually connected to.
- SW_Apr 09, 2019Prodigy
DougB628 wrote:
>> my satellites show devices connected to them that are also shown as connected to the other satellite...
Could be a result of stale/cached info. Give them more time to sync their info or just power cycle all the Satellites first and then follow by the Router itself. This will take a bit of time, but it will refresh the database for the connected devices unless you are running into a config sync problem.
Those of you who live alone, and can do whatever you please with your router / internet connection whenever you please, be aware that you are lucky to have those options. My wife and kids freak out and whine and complain if I cause any issues with the wifi or internet. So I will not be able to do what you suggest until no one is home, or very late at night or very early in the morning.
