SW_
Mar 22, 2019Prodigy
New Orbi RBR50/RBS50 Firmware Version 2.3.1.44
Netgear is pushing out yet another a new Orbi firmware update.
Hopefully it's better than the last version v32.
Please share your experience.
Firmware Update
ealthoff
Apr 06, 2019Aspirant
Is anyone having an issue where the satellite isnt showing any connected devices? I saw discussion on an older firmware but I have version 2.3.1.44 and its still not showing any of my household devices connecting. Will this issue get fixed?
Rustyy
Apr 06, 2019Tutor
Yeah, I just checked my connected divices list. They are all connected to the router other than my PC which is upstairs which is connected via Ethernet. Explains the speed test too as near that my wireless divices get 100+ rest of the house 15-40.
WHY DID THEY BREAK SOMETHING THAT WAS WORKING!?!?!?!?!?!?!??!?!?!!?
edit* In fact, checking the "Network Map" on the app. Both of the satellites are purple with only the router green. The "Waiting to connect" curse continues.Looks like factory reset might be the only option which I have tried to avoid, with all the drama I had adding the RSB40 to the system.
