SW_
Mar 22, 2019Prodigy
New Orbi RBR50/RBS50 Firmware Version 2.3.1.44
Netgear is pushing out yet another a new Orbi firmware update.
Hopefully it's better than the last version v32.
Please share your experience.
Firmware Update
gr8sho
Apr 07, 2019Virtuoso
Perhaps using all the non DFS channels isn’t neighborly. It doesn’t make sense though for daisychain to impact WiFi speed in a one satellite config.
If I had a few hours alone with the Orbi, I’d try a downgrade test just to prove if there’s an actual change of speed involved.
Zephyr3200
Apr 07, 2019Aspirant
I update RBR/ RBS to v.44 a few days ago and setup from a factory reset.
Everything is perfect except when I download apps to update on IOS devices over the air , music stops on my Sonos system Boost setup wired directly to the RBR... and i stream only TuneIn ...it got worse when I stream Tidal music of course . I got this problem too on previous firmware version. Is there a way to correct it? Thanks.
