SW_
Mar 22, 2019Prodigy
New Orbi RBR50/RBS50 Firmware Version 2.3.1.44
Netgear is pushing out yet another a new Orbi firmware update.
Hopefully it's better than the last version v32.
Please share your experience.
Firmware Update
SW_
Apr 07, 2019Prodigy
Dfran1 wrote:
>> I also enabled jumbo frames in the screen you have to enable telnet on the router, my personal preference...
This can have negative impact on performance if any device (switch/client/IoT/etc.,) in the same network can't handle or doesn't support jumbo frame. Otherwise, it is very useful for xfering big files when all devices in the network support/speak jumbo frame.
Thanks for sharing your setup/config/experience.
SW_
Apr 07, 2019Prodigy
My experience with Daisy-Chain is a little different. My reason for disabling Daisy-Chain was because of 2x latency delay due to the extra hop through the Satellite in the middle. I did my experiment with ping and observe the average time. Latency/response time is much more important when playing games than max wireless download speed.
