SW_
Mar 22, 2019Prodigy
New Orbi RBR50/RBS50 Firmware Version 2.3.1.44
Netgear is pushing out yet another a new Orbi firmware update.
Hopefully it's better than the last version v32.
Please share your experience.
Firmware Update
Zephyr3200
Apr 07, 2019Aspirant
>>> Try disabling the following and see:
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s). <<<<
Why do I have to do all those modifications when all Sonos are wired to the router RBR?
Thanks again
Thanks again
Apr 08, 2019Guru - Experienced User
Daisy chain may effect how the system is working. Something to try at least.
And is Beamforming and WMM enabled?
Thanks again
