SW_
Mar 22, 2019Prodigy
New Orbi RBR50/RBS50 Firmware Version 2.3.1.44
Netgear is pushing out yet another a new Orbi firmware update.
Hopefully it's better than the last version v32.
Please share your experience.
Firmware Update
thombe
Apr 08, 2019Apprentice
Thanks for the detail.
I will be trying this for myself. 44 isn't working well for me where 210 did.
Ben
Apr 08, 2019Guru - Experienced User
Has a full reset on the Orbi been performed after the v44 was applied?
Ben
- thombeApr 08, 2019Apprentice
HI furry, yup, i actually post on this earlier, but easily missed in all the posts.
I'm definitely going back to 210 as this was very solid on my setup.
- FURRYe38Apr 08, 2019Guru - Experienced User
:smileywink:
- FuntasticoApr 08, 2019Aspirant
Had time on the weekend and finally decided to fix my system by switching from router to AP, as my setup already has a router for fiber - well... it totally killed it: nothing worked as it should have anymore until I decided to undo it. 1 min after, everything was back to normal (I even kept Daisy chain tagged although my two sats are forming a nice triangle.
The good old advice also applies to Orbi: never change a running system ;)
(and those having problems in AP mode, perhaps should try the router mode...)
