SW_
Mar 22, 2019Prodigy
New Orbi RBR50/RBS50 Firmware Version 2.3.1.44
Netgear is pushing out yet another a new Orbi firmware update.
Hopefully it's better than the last version v32.
Please share your experience.
Firmware Update
Apr 08, 2019Guru - Experienced User
Has a full reset on the Orbi been performed after the v44 was applied?
thombe wrote:
Thanks for the detail.
I will be trying this for myself. 44 isn't working well for me where 210 did.
Ben
thombe
Apr 08, 2019Apprentice
HI furry, yup, i actually post on this earlier, but easily missed in all the posts.
I'm definitely going back to 210 as this was very solid on my setup.
- FURRYe38Apr 08, 2019Guru - Experienced User
:smileywink:
- FuntasticoApr 08, 2019Aspirant
Had time on the weekend and finally decided to fix my system by switching from router to AP, as my setup already has a router for fiber - well... it totally killed it: nothing worked as it should have anymore until I decided to undo it. 1 min after, everything was back to normal (I even kept Daisy chain tagged although my two sats are forming a nice triangle.
The good old advice also applies to Orbi: never change a running system ;)
(and those having problems in AP mode, perhaps should try the router mode...)
AP mode should have worked if you had configured the RBR for AP mode and let it reboot. IF the main host router had DHCP enabled then the RBR would have recieved a new IP address ON the WAN port to something from the LAN address pool from your main host router.
Others are having good experiences with AP mode. I guess I'll try this out on the one I have and see.
