SW_
Mar 22, 2019Prodigy
New Orbi RBR50/RBS50 Firmware Version 2.3.1.44
Netgear is pushing out yet another a new Orbi firmware update.
Hopefully it's better than the last version v32.
Please share your experience.
Firmware Update
thombe
Apr 08, 2019Apprentice
HI furry, yup, i actually post on this earlier, but easily missed in all the posts.
I'm definitely going back to 210 as this was very solid on my setup.
Apr 08, 2019Guru - Experienced User
:smileywink:
- FuntasticoApr 08, 2019Aspirant
Had time on the weekend and finally decided to fix my system by switching from router to AP, as my setup already has a router for fiber - well... it totally killed it: nothing worked as it should have anymore until I decided to undo it. 1 min after, everything was back to normal (I even kept Daisy chain tagged although my two sats are forming a nice triangle.
The good old advice also applies to Orbi: never change a running system ;)
(and those having problems in AP mode, perhaps should try the router mode...)
- FURRYe38Apr 08, 2019Guru - Experienced User
AP mode should have worked if you had configured the RBR for AP mode and let it reboot. IF the main host router had DHCP enabled then the RBR would have recieved a new IP address ON the WAN port to something from the LAN address pool from your main host router.
Others are having good experiences with AP mode. I guess I'll try this out on the one I have and see.
- michaelkenwardApr 08, 2019Guru - Experienced User
Remember, when you change the mode of a device on your network, you don't just change one box and expect everything to work, you have to go through a strict regime for getting things up and running.
You should reboot the network in the right order.
- Turn off and unplug the modem.
- Turn off the modem router and computers.
- Plug in the modem and turn it on. Wait 2 minutes.
- Turn on the modem router and wait 2 minutes.
- Turn on the computers.
If that does not work, then reset the modem/router as well.
Maybe you did that. Your account of what happened does not reveal those details.
- bowmahApr 08, 2019Guide
Been using the Orbi system for almost 2 years now. Currently auto-updated to .44 and it has been a nightmare. The Satellite keeps dropping internet connection but clients are still connected to it. What in the world has NG done this time? Come on guys. Most expensive hardware out there and the weak software kills the whole deal...
