SW_
Mar 22, 2019Prodigy
New Orbi RBR50/RBS50 Firmware Version 2.3.1.44
Netgear is pushing out yet another a new Orbi firmware update.
Hopefully it's better than the last version v32.
Please share your experience.
Firmware Update
Funtastico
Apr 08, 2019Aspirant
Had time on the weekend and finally decided to fix my system by switching from router to AP, as my setup already has a router for fiber - well... it totally killed it: nothing worked as it should have anymore until I decided to undo it. 1 min after, everything was back to normal (I even kept Daisy chain tagged although my two sats are forming a nice triangle.
The good old advice also applies to Orbi: never change a running system ;)
(and those having problems in AP mode, perhaps should try the router mode...)
Apr 08, 2019Guru - Experienced User
AP mode should have worked if you had configured the RBR for AP mode and let it reboot. IF the main host router had DHCP enabled then the RBR would have recieved a new IP address ON the WAN port to something from the LAN address pool from your main host router.
Others are having good experiences with AP mode. I guess I'll try this out on the one I have and see.
