SW_
Mar 22, 2019Prodigy
New Orbi RBR50/RBS50 Firmware Version 2.3.1.44
Netgear is pushing out yet another a new Orbi firmware update.
Hopefully it's better than the last version v32.
Please share your experience.
Firmware Update
Apr 09, 2019Guru - Experienced User
| System Uptime v44 | 07:23:35:01 |
- gr8shoApr 10, 2019Virtuoso
FURRYe38 wrote:
System Uptime v44 07:23:35:01 Meh. That’s not really a big deal IMHO. More important to know performance is correct.
I’m making preparations to uncheck daisychain and will be doing some before and after speedtests. Been a long time since I had to use telnet...
- FURRYe38Apr 10, 2019Guru - Experienced User
Performance is correctly I do get to spec speeds both wired and wireless. 200/10.
Uptime is important as well. Shows that the system hasn't rebooted, crashed or done anything to cause down time. Shows normal operation time.
Daisy chain is disabled since I only have 1 satellite.
- gr8shoApr 10, 2019VirtuosoAnyone know what the parameter auto_autoupg is used for? I set it to 0.
