SW_
Mar 22, 2019Prodigy
New Orbi RBR50/RBS50 Firmware Version 2.3.1.44
Netgear is pushing out yet another a new Orbi firmware update.
Hopefully it's better than the last version v32.
Please share your experience.
Firmware Update
eljarviso
Apr 09, 2019Luminary
I’ve noticed the same problem with my orbi. My AppleTV will also show poor throughput after a while and also require a reboot. I’m running mine in AP mode. Next time it happens I’m going to try a disconnect and reconnect instead of a reboot.
Apr 09, 2019Guru - Experienced User
Try a factory reset and setup from scratch.
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
What WPA security modes are you using?
Try enabling WMM, Beamforming and MIMO. Under Advanced Tab/Advanced Settings/Wireless Settings
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
- 1midniteriderApr 10, 2019GuideUhm... We went through these questions on the .32 release, nothing has changed. I am stable on .210, with manual update in affect. I'll keep reading the release notes and when it appears that version will correctly address my issues, then I'll perform the upgrade.
