SW_
Mar 22, 2019Prodigy
New Orbi RBR50/RBS50 Firmware Version 2.3.1.44
Netgear is pushing out yet another a new Orbi firmware update.
Hopefully it's better than the last version v32.
Please share your experience.
Firmware Update
DougB628
Apr 09, 2019Apprentice
First, I'm not sure what is wrong with the Model field - I haven't been able to select my model in at least a week. If I type Orbi in there, the options do not include my model.
Next - while trying to confirm that I truly had Daisy Chain disabled, it appeared that I did not. Further investigation reveals that satellites also have their own debug.htm page, and one of the items that appears is "Disable Daisy-Chain". One of my satellites has that checked, the other does not. Looking at the wifi signals around my house, I do see more hidden Netgear signals than I think I should. My understanding is that Daisy-Chain is implemented for wireless by the satellites also enabling a backhaul 5G signal.
For kicks, after realizing that you can Telnet to satellites as well as the router, I dumped the config (config show > config.txt) from both of my satellites, and transferred them to my MacBook Pro. I sorted them, then compared them. There are many differences, some of which seem unexpected. One thing I did NOT find that I expected to, was a setting that was obviously the daisy-chain config.
I'm guessing the only way to get daisy-chain disabled on both of my satellites is to turn it back on and then off again, which means I get to restart twice...
