SW_
Mar 22, 2019Prodigy
New Orbi RBR50/RBS50 Firmware Version 2.3.1.44
Netgear is pushing out yet another a new Orbi firmware update.
Hopefully it's better than the last version v32.
Please share your experience.
Firmware Update
eljarviso
Apr 09, 2019Luminary
I’ve noticed the same problem with my orbi. My AppleTV will also show poor throughput after a while and also require a reboot. I’m running mine in AP mode. Next time it happens I’m going to try a disconnect and reconnect instead of a reboot.
DougB628
Apr 09, 2019Apprentice
I've tried switching bands (I'm running with split SSID's), and it sometimes helps, but often does not. The restart of the Apple TV doesn't always help either, but it helps most of the time.
