SW_
Mar 22, 2019Prodigy
New Orbi RBR50/RBS50 Firmware Version 2.3.1.44
Netgear is pushing out yet another a new Orbi firmware update.
Hopefully it's better than the last version v32.
Please share your experience.
Firmware Update
gr8sho
Apr 10, 2019Virtuoso
FURRYe38 wrote:
System Uptime v44 07:23:35:01
Meh. That’s not really a big deal IMHO. More important to know performance is correct.
I’m making preparations to uncheck daisychain and will be doing some before and after speedtests. Been a long time since I had to use telnet...
Apr 10, 2019Guru - Experienced User
Performance is correctly I do get to spec speeds both wired and wireless. 200/10.
Uptime is important as well. Shows that the system hasn't rebooted, crashed or done anything to cause down time. Shows normal operation time.
Daisy chain is disabled since I only have 1 satellite.
- gr8shoApr 10, 2019VirtuosoAnyone know what the parameter auto_autoupg is used for? I set it to 0.
Are you in router mode or AP mode?
Didn't mean to suggest uptime wan't important, it is. But in the grand scheme of issues, that isn't typically the problem but rather devices not connecting or overall poor performance.
- FURRYe38Apr 10, 2019Guru - Experienced User
IMO it's both. Yes performance is a main factor.
7+ days was in router mode. Just changed to AP mode yesterday.
