SW_
Mar 22, 2019Prodigy
New Orbi RBR50/RBS50 Firmware Version 2.3.1.44
Netgear is pushing out yet another a new Orbi firmware update.
Hopefully it's better than the last version v32.
Please share your experience.
Firmware Update
KingJamesKing
Apr 10, 2019Aspirant
I have been running 2.3.1.44 for a while now and noticing these messages in log. These are coming from Satellite 2 Mac address. Any ideas?
Tuesday, April 09, 2019 10:25:19
[WLAN access rejected: incorrect security] from MAC address 9a:3b:ad:17:a8:61
i have RBR53 one router and two satellites
- thombeApr 11, 2019Apprentice
[WLAN access rejected: incorrect security] from MAC address 9a:3b:ad:17:a8:61i have RBR53 one router and two satellites
I get these also, and have had for some while.
Following to see what people say here.
rbk50 in ap
- FURRYe38Apr 11, 2019Guru - Experienced User
Hows was your system updated? Auto update or did you manually update with FW files?
Update and continue or factory reset and setup from scratch after the update?
- KingJamesKingApr 16, 2019Aspirant
I manually updated to .32 then it auto updated to .44
- FURRYe38Apr 16, 2019Guru - Experienced User
You might manually re-load v44, factory reset, then setup again...
Something trying to access your wifi network incorrectly?
I would turn off all wireless devices, then clear the logs on the RBR. Then turn on 1 by 1 yoru wireless devices and see if the logs pick up anything...
The MAC address that is denied is the satellite address not a MAC address of something trying to connect to WiFi. The particular satellite in question always appears to be connected.
I think others see this error as well seems to be a bug but not sure if it affecting anything.
