SW_
Mar 22, 2019Prodigy
New Orbi RBR50/RBS50 Firmware Version 2.3.1.44
Netgear is pushing out yet another a new Orbi firmware update.
Hopefully it's better than the last version v32.
Please share your experience.
Firmware Update
KingJamesKing
Apr 10, 2019Aspirant
I have been running 2.3.1.44 for a while now and noticing these messages in log. These are coming from Satellite 2 Mac address. Any ideas?
Tuesday, April 09, 2019 10:25:19
[WLAN access rejected: incorrect security] from MAC address 9a:3b:ad:17:a8:61
i have RBR53 one router and two satellites
Apr 11, 2019Guru - Experienced User
Hows was your system updated? Auto update or did you manually update with FW files?
Update and continue or factory reset and setup from scratch after the update?
- KingJamesKingApr 16, 2019Aspirant
[WLAN access rejected: incorrect security] from MAC address 9a:3b:ad:17:a8:61i have RBR53 one router and two satellites
I manually updated to .32 then it auto updated to .44
- FURRYe38Apr 16, 2019Guru - Experienced User
You might manually re-load v44, factory reset, then setup again...
- KingJamesKingApr 17, 2019Aspirant
I did the reset on the satellite, poerwed off removed it, powered on with reset pushed. Now instead of one of the messages per day the log records them constantly.9a:3b:ad:17:a8:61, Wednesday, April 17, 2019 17:59:16
[WLAN access rejected: incorrect security] from MAC address 9a:3b:ad:17:a8:61, Wednesday, April 17, 2019 17:54:05
[WLAN access rejected: incorrect security] from MAC address 9a:3b:ad:17:a8:61, Wednesday, April 17, 2019 15:27:17
[WLAN access rejected: incorrect security] from MAC address 9a:3b:ad:17:a8:61, Wednesday, April 17, 2019 15:12:10
[WLAN access rejected: incorrect security] from MAC address 9a:3b:ad:17:a8:61, Wednesday, April 17, 2019 14:53:24
[WLAN access rejected: incorrect security] from MAC address 9a:3b:ad:17:a8:61, Wednesday, April 17, 2019 14:27:14
[WLAN access rejected: incorrect security] from MAC address 9a:3b:ad:17:a8:61, Wednesday, April 17, 2019 14:14:45
[WLAN access rejected: incorrect security] from MAC address 9a:3b:ad:17:a8:61, Wednesday, April 17, 2019 13:59:08
[WLAN access rejected: incorrect security] from MAC address 9a:3b:ad:17:a8:61, Wednesday, April 17, 2019 13:37:41
