SW_
Mar 22, 2019Prodigy
New Orbi RBR50/RBS50 Firmware Version 2.3.1.44
Netgear is pushing out yet another a new Orbi firmware update.
Hopefully it's better than the last version v32.
Please share your experience.
Firmware Update
Apr 13, 2019Guru - Experienced User
I had good operation with v44 in router and AP mode on v44. Zero issues including using a single SSID.
| System Uptime | 07:23:35:01 |
gr8sho
Apr 14, 2019Virtuoso
I’m seeing this topic come up over and over again. Why run the Orbi in AP mode over native router?
- 1midniteriderApr 14, 2019GuideI choose AP mode because I have Verizon Fios with DVR. I had setup Orbi in router mode to simulate how the DVRs are handled, but would quite often have connection issues where a movie would just pause for not apparent reason and remotely accessing the DVR was iffy at best. Playing on demand movies was also problematic, most times it would work flawlessly, but at the seemingly wrong times it cause pixelation. So now the Verizon router handles the DVRs and dhcp. Wifi is turned off on the Verizon router and Orbi handles Wifi. In this fashion there is peace in the house when it comes to TV time...
- michaelkenwardApr 14, 2019Guru - Experienced User
gr8sho wrote:
Why run the Orbi in AP mode over native router?Mostly because many people have other routers, or modem routers, that offer features that you cannot get with an Orbi system, such as ReadySHARE and USB devices.
The big advantage of the Orbi is its wifi and having two routers on your network can cause headaches.
- gr8shoApr 14, 2019Virtuoso
Thanks.
I get the dig. :) Not sure though what percentage of users have needs for those two items, I know I don't, and I'm probably missing out on something...
Didn't want to bias the discussion in any way with my original question. It certainly seems those that do run in AP mode are able to trust the host router to work well. And then there are some of us that don't trust the host router and prefer complete isolation or as close to it as possible. And even in this case, the host router still may have a job to do, for instance managing IPTV traffic.
- SW_Apr 14, 2019Prodigy
If both modes are being equal, meaning you don't depend on features/functions that the old router provides or Mickey Circle/Armor/etc with the Orbi, it boils down to flexibilty and complexity vs. simplicity.
Flexibility:
I found that it's less disruptive to configure/put Orbi in AP Mode and plug it into existing network than to disable old router or replace it with Orbi in Router Mode.
Also, if my Orbi stops working, say due to auto-update, I can turn off Orbi and turn the WiFi on the old router and contunue with my work until I have down time to figure out the problem with Orbi. However, if put my Orbi in Router Mode, I will be in deep trouble and have to scramble to bring my old router back to life in order to continue to do my work.
Complexity vs Simplicity:
Two devices to manage in AP Mode instead of 1 in Router Mode
