SW_
Mar 22, 2019Prodigy
New Orbi RBR50/RBS50 Firmware Version 2.3.1.44
Netgear is pushing out yet another a new Orbi firmware update.
Hopefully it's better than the last version v32.
Please share your experience.
Firmware Update
Apr 09, 2019Guru - Experienced User
Try a factory reset and setup from scratch. I've had zero issues with wifi dropping with v44 loaded. Others as well. Just need a factory reset and setup from scratch is all.
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Try enabling Beamforming and MIMO and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
SBell wrote:
I've been having non stop wifi dropouts since this firmware update was pushed out. I have to restart the RBR50 and two RBS50 sattelites every 20-30 minutes just to get it to work for a little while. I've owned the Orbi for 1.5 years and have gone through multiple periods of huge dropout issues related to firmware updates. I dont have the time or patience to spend half a day trying to revert back to an earlier firmware version or trying to troubleshoot Netgear's shoddy hardware and software engineering. The only reason I've kept it this long is because it cost so much I wanted to at least get some use out of it before tossing it in the dumpster. Going to start looking for an alternative this time. It's not worth the constant hassle to keep the Orbi. Will definitely never buy a Netgear product again!
housevampire
Apr 15, 2019Tutor
Well guys in the end i just took the option of factory resetting the Router & the Satellites over the weekend....
&& to my surprise everything works fine...no issues seen for the last 2 days
- NO Config Sync issue
- WiFi speed has improved drastically back to how it was before the latest FW update
Thank you for all your help guys
