SW_
Mar 22, 2019Prodigy
New Orbi RBR50/RBS50 Firmware Version 2.3.1.44
Netgear is pushing out yet another a new Orbi firmware update.
Hopefully it's better than the last version v32.
Please share your experience.
Firmware Update
Apr 11, 2019Guru - Experienced User
Hows was your system updated? Auto update or did you manually update with FW files?
Update and continue or factory reset and setup from scratch after the update?
KingJamesKing wrote:
I have been running 2.3.1.44 for a while now and noticing these messages in log. These are coming from Satellite 2 Mac address. Any ideas?
Tuesday, April 09, 2019 10:25:19
[WLAN access rejected: incorrect security] from MAC address 9a:3b:ad:17:a8:61
i have RBR53 one router and two satellites
KingJamesKing
Apr 16, 2019Aspirant
I manually updated to .32 then it auto updated to .44
- FURRYe38Apr 16, 2019Guru - Experienced User
You might manually re-load v44, factory reset, then setup again...
[WLAN access rejected: incorrect security] from MAC address 9a:3b:ad:17:a8:61i have RBR53 one router and two satellites
- KingJamesKingApr 17, 2019Aspirant
I did the reset on the satellite, poerwed off removed it, powered on with reset pushed. Now instead of one of the messages per day the log records them constantly.9a:3b:ad:17:a8:61, Wednesday, April 17, 2019 17:59:16
[WLAN access rejected: incorrect security] from MAC address 9a:3b:ad:17:a8:61, Wednesday, April 17, 2019 17:54:05
[WLAN access rejected: incorrect security] from MAC address 9a:3b:ad:17:a8:61, Wednesday, April 17, 2019 15:27:17
[WLAN access rejected: incorrect security] from MAC address 9a:3b:ad:17:a8:61, Wednesday, April 17, 2019 15:12:10
[WLAN access rejected: incorrect security] from MAC address 9a:3b:ad:17:a8:61, Wednesday, April 17, 2019 14:53:24
[WLAN access rejected: incorrect security] from MAC address 9a:3b:ad:17:a8:61, Wednesday, April 17, 2019 14:27:14
[WLAN access rejected: incorrect security] from MAC address 9a:3b:ad:17:a8:61, Wednesday, April 17, 2019 14:14:45
[WLAN access rejected: incorrect security] from MAC address 9a:3b:ad:17:a8:61, Wednesday, April 17, 2019 13:59:08
[WLAN access rejected: incorrect security] from MAC address 9a:3b:ad:17:a8:61, Wednesday, April 17, 2019 13:37:41- SW_Apr 17, 2019Prodigy
If you are running out of option, go to the Satellite telnet terminal, type:
1. config default
2. config commit
3. reboot
After the Satellite comes back online and establishes "Good" backhaul connection, check the logs again. If you see the same error messages, then try generating a new "Backhaul Password" and see if that helps.
Good luck!
