SW_
Mar 22, 2019Prodigy
New Orbi RBR50/RBS50 Firmware Version 2.3.1.44
Netgear is pushing out yet another a new Orbi firmware update.
Hopefully it's better than the last version v32.
Please share your experience.
Firmware Update
Apr 18, 2019Guru - Experienced User
After v74 was applied to the RBS and then RBR, you can directly update the RBS to v44. Not need to load an intermediate version. v212 will be needed to go from v74 to v44 on the RBR however.
AlienMindBender wrote:
I had purchsed my RBK-53 from Costco last month. It was on firmware version 1.4.0.18, and would never find new updates. I had not disabled auto-updates. I began checking into updates, and found a recommendation to go to 2.0.0.74, then follow Netgear's release notes to update to 2.2.1.212 prior to the latest 2.3.1.32 or .44 updates.
I updated the satellites, then the router to 2.0.0.74. The administration page showed a small banner that a new firmware was available. I didn't think at the time to disconnect from the Internet, though I'd already downloaded all the necessary firmware packages. I then began the install on one satellite to 2.2.1.212. However, after the update on that first satellite completed, I was not able to reach the router or either satellite for a few minutes. When it finally came back online, the router and both satellites displayed 2.3.1.44.
So far, everything seems stable despite the router not following Netgear's own "required" step of going to 2.2.1.212 before the current version. I'll have to monitor and see what changes.
AlienMindBender
Apr 18, 2019Aspirant
FURRYe38 - I had been intending on manually updating, but both RBR and RBS auto updated on their own past .212. Do I need to downgrade the router back to .212, then upgrade to .44 again, or do you think it'll be okay since it was an auto update?
- FURRYe38Apr 18, 2019Guru - Experienced User
No, once the RBR is on v212 or v44 no need to downgrade.
Try the manual v44 FW re-load on both, after each has been re-loaded, factory reset the system then walk thru the setup wizard...
