SW_
Apr 18, 2019Prodigy
New Orbi RBR50/RBS50 Firmware Version 2.3.1.48
Netgear just pushes out another firmware version, 2.3.1.48.
Please share your experience!
Dabbit
Apr 20, 2019Aspirant
Thank you. Although my 2 satellites are listed in the ADVANCED / ONLINE UPDATE tab, The two satellites show as 'waiting for connection'. On the manual tab, therefore, they are not available to select to update manually. I have my router set in AP mode, if that matters.
LoboTommy
Apr 20, 2019Luminary
sound a lot like the issues that goes around with the orbi RBR20 and RBS20 series. The RBS20 disconnects all the time. Did a factory reset on all satelites and routers, set up the netwoek from scratch, then had to cableconnect the pc to the router - logged in, and hit the "update" button the instance the satelite connected. Was a nightmare.
I rolled back to the v2.3.1.44 firmware on all routers. But it is still unstable. The satelites disconnects, reconnects, disconnects etc over and over and over.
- lw187Apr 22, 2019GuideHow do you roll back?
- FM2019Apr 22, 2019Aspirant
Did you found a fix for the RBR20 disconnection after updating firmware to .48?
I have the same anoying problem. I had no issues with firmware .44. Now this Orbi is useless. Will a new firmware be rolled out to fix this?
- LoboTommyApr 22, 2019LuminaryHere's the fix...
