SW_
Apr 18, 2019Prodigy
New Orbi RBR50/RBS50 Firmware Version 2.3.1.48
Netgear just pushes out another firmware version, 2.3.1.48.
Please share your experience!
lw187
Apr 22, 2019Guide
Nest cams dropping consistently since upgrade
Dfran1
Apr 22, 2019Apprentice
My wifi cameras are getting weaker signal today, nothing like 210 that was great, might be time to factory reset and try that, one day this stuff works the next day they don't, I changed nothing, do these things have AI built in, it certainly seems so. Also my wifi channels are locked that worked perfectly on 210 for days, not like this one day good the next bad. If I could just keep it on 210, hopefully tonight I can a factory reset and kill lots of time I don't have for this.
- lw187Apr 22, 2019Guide
i have one router and three satellites. the router is in ap mode, the satellites are hardwired to router.
since the upgrade, satellites appear to be consistently dropping out and reconnecting. that appears to be the cause of my nest cams dropping out.
i rolled back to previous firmware and all is well.
- csm2000Apr 22, 2019Tutor
Finally, I solved the problem I was experiencing with the inability of my 2 Orbi Satellites to stay connected with my Orbi router. After attempting to upgrade to v48, I was left with the router and 2 satellites on 2 different firmware versions. Unfortunately, there was no apparent downloadable firmware file available from Netgear for a manual upgrade of a completely unstable system that wouldn’t remain connected to its other components. Accordingly, I shut it off, tore it down, boxed it up and returned it to Costco and got my money back. Netgear can’t get it right with this product. Loved it when it worked but, oh what a mess!
- FURRYe38Apr 22, 2019Guru - Experienced User
Users need to try a factory reset and setup from scratch as this seems to solve problems after a FW update.
no thanks. id rather netgear just make a ready for prime time update that isn't glitchy. ill wait for that
