SW_
Apr 18, 2019Prodigy
New Orbi RBR50/RBS50 Firmware Version 2.3.1.48
Netgear just pushes out another firmware version, 2.3.1.48.
Please share your experience!
lw187
Apr 22, 2019Guide
i have one router and three satellites. the router is in ap mode, the satellites are hardwired to router.
since the upgrade, satellites appear to be consistently dropping out and reconnecting. that appears to be the cause of my nest cams dropping out.
i rolled back to previous firmware and all is well.
Apr 22, 2019Guru - Experienced User
Users need to try a factory reset and setup from scratch as this seems to solve problems after a FW update.
- lw187Apr 22, 2019Guide
no thanks. id rather netgear just make a ready for prime time update that isn't glitchy. ill wait for that
- FURRYe38Apr 22, 2019Guru - Experienced User
Good luck with that. Seems to be an issue on going with auto update and continuing after a FW update. A reset ensures that any possible lingering code and mis-configurations are cleared out. This is one issue that has been on going for a long time now. Reset does fix most problems though. No issues with my systems doing a reset and setup from scratch.
Good Luck.
