SW_
Apr 18, 2019Prodigy
New Orbi RBR50/RBS50 Firmware Version 2.3.1.48
Netgear just pushes out another firmware version, 2.3.1.48.
Please share your experience!
lw187
Apr 22, 2019Guide
no thanks. id rather netgear just make a ready for prime time update that isn't glitchy. ill wait for that
Apr 22, 2019Guru - Experienced User
Good luck with that. Seems to be an issue on going with auto update and continuing after a FW update. A reset ensures that any possible lingering code and mis-configurations are cleared out. This is one issue that has been on going for a long time now. Reset does fix most problems though. No issues with my systems doing a reset and setup from scratch.
Good Luck.
